DIAdem
Command to display a certain tab in View
I have a script which loads a TDV.  This TDV has many tabs.  How can I force a certain tab to be displayed in View?  I have tried this (without success): -
View.Sheets("Home").activate
View.AutoRefresh = true
View.Refresh
call WndShow("View")
'Home' is the name of the sheet I want to be displayed.  The above script selects the 'View' panel, but opens the wrong tab.   I cannot find the commands to open the correct tab.  I use Diadem 2015.   Any help is much appreciated.
Thanks!
Thomas
(3,074 Views)
Accepted by topic author mrme
Hello Thomas,
This code works for me:
Call WndOpen("VIEW")
Call View.Sheets("Home").Activate
I tried this in DIAdem 2017 Beta 5, but that should work in earlier versions of DIAdem just as well. Please make sure that the sheet name doesn't include a space or other characters, if I add a space to "Home " (at the beginning or end) the command fails.
If you continue to have issues, can you post the VIEW layout for me to test?
   Otmar
Otmar D. Foehner
(3,050 Views)
Hi Otmar,
It works.  Thanks for the support!
Regards
Thomas
(3,030 Views)
