DIAdem
Command to reassign number channels
Hello.
I have ordered the channels in the data portal (Structure) using the bubble method. Now I am interested in reassigning the original channel numbers (list) with the order shown in the data portal.
Is there a command to do this? Do I have to use the Bubble Method again?
(3,703 Views)
Hello!
You can use the ChnRenumber command.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,696 Views)
Thank you, very much. Regards, Luis.
(3,686 Views)
