DIAdem
Comment out line of script
Is there a way to select several lines of script and comment out the lines so they don't run.  And be able to uncomment them.
(3,689 Views)
Answered here...
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,687 Views)
you can do it freestyle:
If(5=6) Then
 . . . codelines you do not want to execute
End If
For a quick test you also can switch this block on (5=5) again and also off (5=6).
Best Regards
Martin Liese
(3,655 Views)
