DIAdem
Comment out lines of script
Is there a way to select several lines of script and comment out the lines so they don't run.  And be able to uncomment them.
(9,308 Views)
Hello!
No, there is only a line comment and no block comment. You can use a external editor like Notepad++ (free) or UltraEdit (comercial). There you can select multiple line and comment them in/out in one step. DIAdem is missing this feature.
If you only have global code you can use another trick: Just build a Sub around.
Matthias
Message Edited by Twigeater on 01-14-2010 09:35 PM
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(9,305 Views)
Hi bm2cox
Please refer tho the DIAdem help index keyword "Shortcuts" and the section "Script". In DIAdem SCRIPT press CTRL + ' (single quotation mark) to comment  or CTRL+ Shift + ' to uncomment selected lines. In the latest version you can also  press CTRL +  D (The '-sign makes some problems with asian keybords).
Hope this help
Winfried
(9,287 Views)
The Ctrl + ' does not seem to work in Version 10.2
(9,274 Views)
Hi
you are right, this is available in DIAdem 11.0 an later. The SCRIPT module was completely revised  and has a lot of new feature (e.g. codecompletion).
Winfried
(9,271 Views)
Just for additional info.
Ctrl+D will comment out the selected lines.
Ctrl + Shift + D will uncomment selected lines.
Rob S
(7,994 Views)
