DIAdem
Communicating with MATLAB Example
I stumbled across the Communicating with Matlab example and I was really excited that the example generates identical results between MatLab and DIadem when calling an FFT
This seems to work really well with the sine wave generated in the example but has anyone ever tried to tweak the example to work with real data?
The reason I have asked this is I have a matlab script to analyze data using an FFT and I wanted to translate it such that I would run it exclusively in DIAdem and I cannot get to seem the example to get me similar results when using "real" data.
Tim
(4,218 Views)
Hi Tim,
If you'll email me at brad.turpin@ni.com, I'll give you the back story here.  It's possible that we can help you modify the example to do what you want it to, but you'll need to provide the MatLab knowledge and testing environment.
Brad Turpin
DIAdem Product Support Engineer
(4,188 Views)
