DIAdem
Compare two numbers with tolerance
I would like to compare two numbers and set an interval to. The first number is n1= 100 the second number is n2= 105
number = 0
If n1 = 105 + - 10 then
   number = number +1
End if
The variable number should be 1 in this case.
Thank you very much in advance.
With best regards,
Mosquito
(5,505 Views)
Hi Mosquito,
you can try this:
dim a, b, c
a= 95
b= 105
c=100
if ( (C>A) AND (C<B) ) THEN
  Call msgbox("Test")
End If
Kind Regards,
Philipp K.
AE | NI Germany
(5,485 Views)
