DIAdem
Component ActiveX can´t create object: 'GetObject'
Hi All,
I am having following issue with Diadem Script. The script itself is functional, hovewer, I recently installed it on new computer. When I try to run it, I am getting error "Component ActiveX can´t create object: 'GetObject'" (In attached file last line is in different language but means just that). I suspect that some PC/Diadem settings might be an issue, but so far had no luck detecting the source. Any idea about possible solution would be most welcome.
(3,635 Views)
(3,613 Views)
