DIAdem
Contour plot (X,Y,Z) when Z is a Matrix in Diadem
I am trying to write a Script to Plot a contour graph x,y,z when every component is a column of a Table except Z, is a matrix ( several Columns)
anyone help me with the script. I tried recording it but it does Not give me enough information. And there is no infos about contour matrix in the Manuel.
Thanks in Advance
(3,010 Views)
If you have configured it the correct way you can open the config DIAlog in Report and press
CTR+Shift+C
This will put the vbs code into clipboard that you need to configure your plot like it is done currently.
Go to script and press
Ctrl+V
to insert the clipboard into the script editor.
In combination with teach in this shoudl give you enoug information to write your script.
(2,966 Views)
