DIAdem
Converting Specific Calculator AUT to VBS Syntax
I am going through a particular example that has AUT calculator syntax.  I usually use Script myself, but am trying to show someone how to use the calculator.  I cannot figure out how to do the same thing in a one-line VBS syntax (in the calculator).
Here is the AUT format:
Ch('Result') := ('Speed'>=100)*'Speed' + ('Speed'<100)*NV
Please help!
Thank you,
Julia Moeller
(3,803 Views)
Hi Julia,
With the VBS syntax in the calculator we introduced the new function CTNV. Please refer to the help. For your calculation try the following formula:
Ch("Result") = Ch("Speed") + CTNV((Ch("Speed")<100))
Hope that helps,
Ralf
NI Aachen
(3,798 Views)
Thank you Ralf, that works perfectly!
(3,796 Views)
