DIAdem
Copy and save an Excel sheet with Diadem from an existing Excel file
I wanted to copy an Excel sheet from an Excel file and then save it as a separate file in a folder that I could define.
I write down the following Code:
Option Explicit
Dim myExcel, objWorkbook
Set myExcel = CreateObject("Excel.Application")
myExcel.Visible = false
Set objWorkbook = myExcel.Workbooks.Add
Call myExcel.Workbooks.Open("C:\Users\Root\Document\Data.xlsx")
myExcel.Sheets("Data_Sheet_2").Select
myExcel.Sheets("Data_Sheet_2").Copy
objWorkbook.SaveAs "C:\Users\Root\Download\test.xlsx"
The problem with this code is that the newly saved file opens two Excel files. One has the name "test.xlsx" (and is empty) and the other is called "Excel" and this file is the copied sheet from the main Excel file ("Data.xlsx").
Does anyone know why the saved file opens two Excel files and how I can fix this?
(2,386 Views)
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim myExcel, objWorkbook, objWorkSheet, objSheet
Set objWorkSheet = objWorkBook.Open("C:\Users\111660\Desktop\Data.xlsx")
Call objWorkSheet.SaveAs("C:\Users\111660\Desktop\test.xlsx")
Set objWorkSheet = objWorkbook.Open("C:\Users\111660\Desktop\test.xlsx")
Call objWorkSheet.sheets("Sheet1").Delete()
Call objWorkSheet.sheets("Sheet3").Delete()
Call objWorkbook.Close()
(2,329 Views)
