DIAdem
Copy matrix to DIAdem
does anyone know how to import or copy easily a matrix ( see example matrix attached) to Diadem?
(2,429 Views)
Hi DDM57,
There is no predefined way to import a matrix into Diadem. You will need to import your Excel file with the import wizard and define how you want to manage the file in that wizard. If you would like to copy many of those matrices, you can create your own plugin that will give you an easy way to continue to import in the future. You can see instructions for this process on this page.
Thank you,
Casey
Casey G.
(2,402 Views)
