DIAdem
Creating a PDF Report through LabVIEW Diadem Connectivity VI's
Hello, I have the following issue when running the DIAdem Connectivity VI's from Labview. I have created the VI linked below, which loads a tdms file, a report layout and a script which plots data to my graphs on the layout. When loading the files manually into Diadem and running the script everything works as expected. But when running from Labview, Diadem opens but no pdf file is created. The PDF file is created in the script. Is there anything I am missing?
I have posted the same question to the LabVIEW forum but have recieved no answer.
Thank you.
(2,386 Views)
Hi alexkon,
I know this is an older post but I just came across it as I am having similar issues and think I may have narrowed some things down. I made basically the same vi, and got it to work when I downloaded 32 bit DIAdem since I was using 32 bit Labview. After DIAdem 2017 there is only a 64 bit option though, so I am struggling to find a good way to programmatically generate reports using 32 bit Labview without having to use an older version of DIAdem. If installing a different version of DIAdem is an option for you then match the bitness and that might do the trick for you!
(2,097 Views)
