DIAdem
Creating a report Master Template
I am looking to create a master template that includes the company logo as well as other text boxes including information about the test.  I want this to repeat on every sheet of the report.  The template I saved does not bring this information forward to the next sheet added?  I have set this template to be the default upon diadem launch and when a "new sheet" is selected.  This is referenced as Master Layout in the Diadem Course Manual (2010 pg 4-22)
Thank you-  Dan Trudell
(4,389 Views)
Hello Dan,   I was able to first create a master Layout using the directions at the following link:   http://zone.ni.com/reference/en-XX/help/370859H-01/exploff/examples/masterlayout_example/
After creating the master I would typically just use the "Copy..." command to move that master template down the line.   Is this the functionality you were looking for?
(4,376 Views)
