DIAdem
Creating template
Hi diadem people
My goal is to create a template like that underneath. By using Diadem report VI i want to make an PDF file out of it
The values filed in the spaces in the templates will be string/number indicator generated in the main VI.
How should i go forward creating this template ??
(4,422 Views)
Hi LCT2,
I would recommend that you save all the descriptive properties and table values and curve points to a TDMS file in LabVIEW, then have DIAdem load that TDMS file and load a predefined REPORT template (TDR file).  That way you can (pre-)define the TDR file easily in DIAdem by just manually loading the TDMS file, manually creating the TDR file, then saving the TDR file.
I can help with programmatically telling DIAdem to load the TDMS file and the TDR file.
Brad Turpin
DIAdem Product Support Engineer
(4,408 Views)
