DIAdem
Critical Bug, Diadem crashes with no notice
When I type the code below into a script, and then press return while the curser is to the left of the colon (":"), Diadem abruptly crashes.  I found this out while editing a script, but it will do it on a fresh start of Diadem.  My version is 12.0.0f4991.  I don't need it fixed for me, I'm just reporting a bug.
Call GlobalDim("Test"):Test=1
Also, Is there a bug report system on the website?
(6,772 Views)
Hi RussellSenior,
Thanks for reporting the bug!!  I went ahead and submitted a Corrective Action Report, #438773, on the issue.  The best ways to report these bugs are to make a service request at www.ni.com/support, or post on the forums.  Thanks again.
Peter T
(6,748 Views)
Hi RussellSenior,
We identified the problem and will provide a fix with the next version DIAdem 2014.
Thank you and greetings
Walter
(6,729 Views)
