DIAdem
Cursor positions cause DIAdem VIEW to work slowly
Hi All,
  I have a file that has approximately 180 pages in the VIEW portal, each with a chart.  When processing these charts I employ the Band Cursor to select ranges on each curve and then calculate values based on that range.  Then I move to the next sheet and do the same thing.
  After building lots of pages I notice things slow down significantly.  In the bottom left corner of the screen I see the following message "X-Cursor1: 0.153 Y-Cursor1: 1.63E+04 Z-Cursor1:0" and the values change many times before moving along with my request.  I am pretty sure the program is going through each sheet and reading the cursor positions.  This wastes a lot of time.
  Is there a way to 'turn off' the cursors or do something similar so that this doesn't happen every time I switch into the VIEW module?  Any help would be greatly appreciated.  Thanks in advance!
(5,299 Views)
Hi GT_Mark,
How are you doing those calculations on each sheet?  In your head?  Running a script by clicking with the mouse?  Running a script based on a VIEW cursor move event?
Can you send us the data file and TDV that reproduces this effect?
Brad Turpin
DIAdem Product Support Engineer
(5,252 Views)
Hi Brad,
  Thank you for your feedback.  I've sent you an e-mail containing the relevant DIAdem contents and code.
  To answer some of the questions on here that I did not address specifically oin the e-mail:
     The calculations on each sheet are completed within the script.  Things seem to slow down when the script initiates interaction mode and then the user uses cursors to specify a range of data on a chart.  After clicking to end interaction mode the script continues working.
I hope that clears up some of the ambiguity of how the code is running.
Thanks in advance for your help!
(5,248 Views)
