DIAdem
Custom Properties Copy to DataFileHeaderAccess
Hi everyone!
I'm trying to Update a old Script from Diadem 9.1 and I'm getting some troubles. The Script use to Copy the Root Properties of some .tdms files were the conditions of the test are stored. For that it used the command .RootPropCount, that now is obsolete.
I tried the following Script to get this Count but I do not get the count of the Custom Properties:
Set TdmHdr = CreateDataFileHeaderAccess()
Set oMyDataStore = TdmHdr.Open(DataReadPath & "EXAMPLE.TDMS" , "TDMS", True)
PropCount = oMyDataStore.RootElements(1).Properties.Count
MsgBox (PropCount)
The result is always 8, regardless of the nº of Costum Properties, and the Name of the DataStore Properties are: name, description, title, autor, datetime, registertxt1, registertxt2 and registertxt3.
The .tdms file has indeed more than 30 Costum Properties that are not being obteined...
Please help!
Thank you in advance.
(2,442 Views)
Accepted by topic author Viruje
This is a little pitty because the RootPropCount was doing a second thing internally which was calling
rootProperties.ListInstanceProperties = True
This little line causes the API to also reflect the custom properties (instance properties).
You need to set it to true for every properties object.
So the following code will do the job.
Option Explicit
dim TdmHdr, oMyDataStore, PropCount
dim rootProperties : set rootProperties = oMyDataStore.RootElements(1).Properties
PropCount = rootProperties.Count
MsgBox (PropCount)
 maybe you can just add a function to your code to simplyfy the job
Option Explicit
dim rootProperties : set rootProperties = GetElementProperties(oMyDataStore.RootElements(1))
MsgBox (PropCount)
function GetElementProperties(byref element)
  set GetElementProperties = element.properties
  GetElementProperties.ListInstanceProperties = True
end function
(2,400 Views)
Thank you very much!! Now it works fine.
(2,391 Views)
