DIAdem
Customize the way of defining Y axis channel in chart
Is there a way to define Y axis channel as variable.
Here the chart has X axis: Time and Y axis: Speed
But in my case,  the Y axis name is not fixed. sometime its test1_speed, test2_speed, test3_speed...
so, is it possible to use something like below,
1) Y axis:     [1]/type & "_speed"
where "type" is a global variable and that will have a value either test1, test2, test3.... based on condition.
2) Y axis:   @@Data.Root.ChannelGroups(1).Channels(type & "_speed")@@
thanks
Durai
(1,391 Views)
You can change it in script.  I don't think the 2D axis system configuration supports wildcards...  Are you working in VIEW or REPORT?
(1,348 Views)
Hi gsklyr,
I am trying to do it in report template. since many pages and multiple charts in each page, i am expecting option to do it in report template itself.
regards,
Durai
(1,341 Views)
Maybe use channel numbers instead of names if you can anticipate their order?
Otherwise you can script changing a curve reference with something like that:
Dim atype: atype = "test1"
Dim o2DAxisSystem, o2DLine
Set o2DAxisSystem = Report.Sheets("Sheet 1").Objects("2DAxis1")
Set o2DLine = o2DAxisSystem.Curves2D.Item(1).Shape
o2DLine.YChannel.Reference = "[1]/" & atype & "_speed"
Here I assume you have a sheet named "Sheet 1" and a 2DAxisSystem in that sheet named "2DAxis1"
EDIT:
Actually this worked:
BUT it only plots the first occurrence it finds!  So if I change the order of the channels and put Speed1 on top, it will only plot Speed1
(1,336 Views)
Accepted by topic author Durai26
As gsklyr has already written, the Y channel can be set by script.
If you want to get along without script, then the curve expansion of REPORT can be used. Set these settings in the Layout Parameters dialog. This will replace the wildcard * in your channel names of the REPORT layout.
(1,274 Views)
