DIAdem
D2CurveETType
   I'm writing an autosequence to modify a free text located above a constant courve in diadem report. I use the parameter D2CurveETType but it doesn't work.  This is my code:
    Call GRAPHObjOpen("2DAxis1")
    Call GRAPHObjOpen(D2CurveObj(2))
     D2CurveETType= "Free text"
     D2CurveETTxt  = " 80% limit"
    Call GRAPHObjClose(D2CurveObj(2))
  Call GRAPHObjClose("2DAxis1")
 call picupdate()
 I use Diadem 10 with SP1. Any suggestion?
Thans a lot.
Oriol.
Passive Safety Enginner
Applus Idiada.
(3,959 Views)
Hi Oriol,
did you set the line type "Line and symbol" -  that's necessary. The following script works fine on my PC with DIAdem 10.0 SP1
Call GraphObjOpen("2D-Axis1")
  Call GraphObjOpen("2DObj5_Curve1")
    D2CCURVETYPE     ="Line and symbol"
    D2CURVEETTYPE    ="Free text"
    D2CURVEETTXT     ="My Test"
  Call GraphObjClose("2DObj5_Curve1")
Call GraphObjClose("2D-Axis1")
Greetings
Walter
(3,954 Views)
Hi Walter,
   Thanks for your response.
    If I set line type "Line and symbol" woks fine but I my courve is a constant.  Here is my complete function:
sub addLimit(limit,i)
    Call GRAPHObjnew("2D-Curve","2DObj1-curvelim"&i)
    Call GRAPHObjOpen("2DObj1-curvelim"&i)
     D2CurveInterv=1
     D2CCURVETYPE= "contant"
     D2CCONSTX        = NOVALUE
     D2CCONSTY        = limit
     D2CurveInterv    = 5
     D2CurveLinewidth = "0.3"
     D2CurveETType = "Free text"
     D2CurveETPos = "largest index"
     D2CurveETRelPos="top"
     if (i=0) then
       D2CurveColor     = "red"
       D2CurveETTxt = "Red"
     end if
     if (i=2) then
       D2CurveColor     = "green"
       D2CurveETTxt = "Green"
     end if
   Call GRAPHObjClose("2DObj1-curvelim"&i)
end sub
Greetings,
Oriol Montalà
Passive Safety Engineer
Applus Idiada
(3,947 Views)
Hi Oriol,
in that case you must use D2CONSTETTYPE like:
    D2CONSTETTYPE    ="Free text"
By the way, the easiest way to get all necessary parameters is to use the key combination CTRL-A. Therefore open the axis system - with CTRL-A you can copy all properties into the clipboard and past them later on into your script.
Greetings
Walter
(3,942 Views)
Hi Walter,
   Thanks a lot! Now works fine. I didn't know the power of CTRL+A. This hot key is very cool.
Greetings,
Oriol.
(3,936 Views)
