DIAdem
DAC: Screen is lost when accessing to desktop
When a DAC-plan is running (for instance "example.dac") and the user access to the windows desktop, the diadem screen is destoyed and will not restored when returning to diadem.
The access may be: changing the size of the status line, the "show desktop" from quickstart pallet.
It only occours, while a DAC-plan is running, not while it is editing.
I'm using Win2000Pro.
(4,556 Views)
I have three questions to you.
1. How much memory space is available?
3. Do you have roots/admin rights for your desktop?
2. What DIAdem version you use?
Best regards
Sebastian N
(4,555 Views)
1. I've testet on different systems with different memory configurations 256 MB and 512 MB, but have't see any dependency.
2. I've testet with and without admin-rights, no differences.
3. ver. 8.1; ver. 9.0 and ver 9.1 show this behavior. I have't checked earlier versions of DIAdem.
Remark: This behavior only occurs, when a DAC-plan is running. When a DAC-plan, (or a VISUAL-page) is not running but in editing mode, DIAdem acts absolutly normal and restore its windows.
I think, thats a effect of the so called realtime procesing of DIAdem-DAC
(4,555 Views)
It is a known bug, which should be fixed in DIAdem 9.1. I route this to the development department at National Instruments.
Best Regards
Sebastian N
NI Germany
(4,555 Views)
I have actually the same Problem with Diadem. I think the Problem is after 3 years not really fixed. Btw, I´am using Diadem 10.1. If you have some ideas to fix it, please let me know.
Greets, Karl
Here is a new Thread to this topic:
http://forums.ni.com/ni/board/message?board.id=60&message.id=7952
(4,078 Views)
