DIAdem
DAC decimal to binary
I need to read in the status of 16 digital inputs over rs485 in HEX, convert to binary and extract the status of each DI to visualize and record.
My .atr file works fine. I can read in the status of the inputs and get the right dec values; Channel 1 + 2 (0-255)
Input
Set com6 TO=5000 EOL=\013
Write com6 "@01"
Set com6 TO=5000 EOL=OFF
Read com6 "%1c %2hnb %2hnb %c"
end
Now I need to convert the dec values to 2 binary values (8bit) and extract each bit.
I tried it that way (copied from the board) but it doesnt work... I think syntax, data type or something like that is wrong...
Sub SFD_ProcessChannel( ChannelNumberP, InputListV, ParamP, DataP, ErrorP )
  ' Diese Funktion muss für ein Skript zur Datenverarbeitung implementiert werden.
  ' Zu ergänzen : Geben Sie hier den Code für die Berechnung des gewünschten
  ' Ergebnisses ein.
  DataP = 0
  Dim tmp
  Dim n
    n = InputListV(0)
  tmp = Trim(Str(n Mod 2))
  n = n \ 2
  Do While n <> 0
    tmp = Trim(Str(n Mod 2)) & tmp
    n = n \ 2
  Loop
  DataP = tmp
End Sub
Can somebody help me plz?
thx Mike
(3,820 Views)
Accepted by topic author mleopold
Ok bitextract solved my problem!!
(3,790 Views)
