DIAdem
DAC - dialog box error
Hello Walter,
I try the SUD and the schemes in a trial Diadem11.1 too, but I receive the same error.
You said that you modified only the path from the SUD and you was able to call the schemes with no error.
Then maybe it is an error generated by my computer.
Do you have any suggestion were to look? or how to modify my schemes to be more simple and maybe then get ride of the error?
Marius
Message 11 of 12
(1,241 Views)
Accepted by topic author Marse
Hello to all,
Regarding to my problem I find out that the command MKSCheck was creating my the error.
Now I remove the command, and I use to verify the scheme only the command  SchemeCheck("Normal"), and I don't receive anymore the error.
Thank you for everything.
Marius
Message 12 of 12
(1,156 Views)
