DIAdem
DAQCard DIAdem
Is it possible to reset the counters of a DAQCard 6024E in the VBScript?
Pvh.
(4,335 Views)
Hi PvH,
Please take a look at the following example, it shows how to use do data acquisition from VB Script.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3E41F56A4E034080020E74861&p_...
Karsten
(4,312 Views)
I am sorry, the .html link in the downloaded file doesn't display the example.
I dont have ComponentWorks 2.0 on my computer.
Do you have a solution the display the example?
Thanks!!
Grz,
Pvh
(4,307 Views)
Hi Pvh
The DAQ components are also included in the NI-DAQ Traditional Driver. You don't need Component works if you only use DAQ.
Inorder to download the example you need to log in using a NI Profile. you can do this by using the link 'continue the download process'
Karsten
(4,299 Views)
 I am Loged in, but still don't get it running
The next page shows up:
INTERACTIVE WEB PAGE WITH COMPONENTWORKS ACTIVEX CONTROLS
1) Uses Microsoft ActiveX Control Pad and VBScript to build the HTML page
2) Click on "Plot Random Data" to plot 100 random points
3) Click on "Start Input" to perform Data Acquisition. You need an E-Series Card as Device 1 with signal hooked up to channel one.
Pvh
(4,208 Views)
