DIAdem
DDC_GetNumDataValues shows error code 6202
I am writing a wrapper in C# to read TDM files still.
But I met the error code 6202 using DDC_GetNumDataValues.
        [DllImport("nilibddc.dll", CallingConvention = CallingConvention.StdCall)]
        static extern int DDC_GetDataValues(IntPtr channel, ulong indexOfFirstValueToGet, ulong numberOfValuesToGet, IntPtr values);
IntPtr databuff = Marshal.AllocCoTaskMem((int)(sizeof(double) * numDataValues));
ret = DDC_GetDataValues(channels[i], 0, numDataValues, databuff);
Does Anyone know how to solve this error?
Thanks for any help.
(3,245 Views)
Accepted by topic author Takayama
I solved this issue myself.
I wronged the aggument's type.
[DllImport("nilibddc.dll")]
static extern int DDC_GetDataValues(IntPtr channel, uint indexOfFirstValueToGet, uint numberOfValuesToGet, IntPtr values);
ret = DDC_GetDataValues(channels[i], (uint)0, (uint)numDataValues, databuff);
Thanks.
(3,219 Views)
