DIAdem
DDC_OpenFile Error(-6209) with VB.NET
I used the DDC_OpenFile function of C_DLL_TDM.uri with VB.NET.
The result was Error code  "-6209 FileDoesNotExist".
As VB.NET uses UTF-16 for the character string, I converted it to EUC. Also,I changed FilePath from the Windows format"C:\Users\laser\Desktop\TDMS\A.tdms" to the C format"C:\\Users\\laser\\Desktop\\TDMS\\A.tdms".
※Of course the TDMS file is in place
Refer the code below.
Class TestProgram
<DllImport("C:\Users\laser\Desktop\TDM C DLL\dev\bin\64-bit\nilibddc.dll")>
Private Shared Function DDC_OpenFile(ByRef filePath() As System.Byte, ByRef fileType() As System.Byte, ByRef file As Long) As Integer
'ByRef filePath() As System.Byte, ByRef fileType() As System.Byte, ByRef file As Long) As Integer
End Function
Public Shared Sub Main()
Encoding.RegisterProvider(CodePagesEncodingProvider.Instance)
Dim ret As Integer
Dim file As Long
Dim str As String
Dim filePathbytes() As Byte
Dim fileTypebytes() As Byte
str = "C:\\Users\\laser\\Desktop\\TDMS\\A.tdms"
filePathbytes = Encoding.GetEncoding("EUC-JP").GetBytes(str) '*** UTF16 to EUC
Console.WriteLine(BitConverter.ToString(filePathbytes))
str = "TDMS"
fileTypebytes = Encoding.GetEncoding("EUC-JP").GetBytes(str) '*** UTF16 to EUC
Console.WriteLine(BitConverter.ToString(fileTypebytes))
ret = DDC_OpenFile(filePathbytes, fileTypebytes, file)
Debug.Print(ret)
Debug.Print(file)
End Sub
End Class
Please tell me what is the problem.
Message 1 of 1
(1,694 Views)
