DIAdem
DDE Conversation with Script DAC Driver
How to make a DDE Conversation with the Script DAC Driver?
I've build a DDE-Server "Project2.exe".
I can poke a string from Diadem Script with:
Call DDEOpen("Project2", "DdeServerConv1")
Call DDEPOKETEXT("DdeItem","This text is inserted using DDE",50000)
Call DDEClose()
But I can not make a conversation from Script DAC Driver.
Scriptfile:
Sub SFD_WriteChannel( ChannelNumberP, ParamP, DataP, DoneP, ErrorP )
  DoneP = 1
End Sub
Sub SFD_Init( DeviceParam1V, DeviceParam2V, ErrorP )
End Sub
Sub SFD_DeInit(ErrorP )
    Call DDEClose()
End Sub
When starting DAC, a type mismatch error appears in DDEOpen-command. Is there a way to solve it? I can't use the DDE-Client block from DAC, because I have to transmit strings.
(4,560 Views)
within the Script DAC driver, many DIAdem commands are not supported. This is because the script is executed in a different environment than vbs that run within DIAdem SCRIPT.
Data Exchange and communication is used to be done with the UDI Interface - which does not support DDE operations.
Since VBS does not support DDE neither, there is no easy solution for that communication.
Maybe it is most convenient to write a driver for your DDE communication. DIAdem offers the GPI-DLL interfaces for duch purposes.
Another solution that might work is to write an ActiveX Server application that does the DDE communication and to call the server from the Script DAC driver.
Hope that gives you some ideas how to proceed.
Ingo Schumacher
Systems Engineering Manager CEERNational Instruments Germany
(4,556 Views)
Thanks for the fast answer. It helps.
(4,553 Views)
