DIAdem
DIADEM is not reading data into channels
Hi
I am trying to read a tdms file into DIadem through data Navigation.This conatins 12 columns of data.But when it is loaded it creates large number of channels with lengths (arb~200).I tried to create the data pluggin but the small windows are showing unidetified symbols.Is this due to any setting is not set properly
Certified LabVIEW Developer
(5,177 Views)
I assume that the file contains a lot more columns/channels than you thought.
This might habben because you created a new groups every time you wrote a new chunk
instead of appending to an existing one
group1.mychannel
group2.mychannel
will result in two channels.
Could you make sure your write code does append instead of create.
(5,080 Views)
Hi mj,
Can you post the TDMS file for us to look at?
This should be a non-issue if it loads correctly in LabvIEW.
Brad Turpin
DIAdem Product Support Engineer
(5,024 Views)
hi
we are having 5 licences in our lab in four of the computers it is coming proper .But in the fifth one it is not coming proper
.I tried re installing ,but same issue is there in the particular computer
(4,940 Views)
