DIAdem
DIAdem 10.0 + Projector Problems
Occasionaly, I have meetings at work and use DIAdem 10.0 on a laptop computer with a projector (an Espon Powerlight I think).  If I create a new graph (2D or 3D), the image will "flash" up very quickly, then the REPORT page is nearly blank (someimtes the legend is visible).  If I disconnect the projector cable I experience the same problem, but if I restart DIAdem (projector not hooked up), then all works well.  Has anyone else experienced this problem?  I would appreciate any help!
Thank you,
Julia Moeller
(3,402 Views)
Hi Julia,
I've also seen this problem on a Dell computer and corrected it by installing a new graphics driver from the Dell support page.
The problem also occured when using other application like Microsoft Paint.
Christian
(3,386 Views)
