DIAdem
DIAdem 2010 Runtime Error R6030
Just in case someone has found this thread through a search, here is the link to the DIAdem 2010 Service Pack 1 that should fix this problem:
http://forums.ni.com/t5/DIAdem/Announcing-The-DIAdem-2010-service-pack-1-is-available/td-p/1394914
Otmar D. Foehner
Message 11 of 14
(1,844 Views)
After rebooting, repairing, reinstalling, finding this thread through the search & installing SP1 (twice), I still had the problem.  Much later I closed a Webex session - I was host & sharing desktop.  Before shutting down for the day I tried DIAdem 1 last time - worked fine.  tested the theory & confirmed.  you can share desktop even if you're sharing diadem, but diadem has to be already running in advance.
Message 12 of 14
(1,680 Views)
Hi, since few week I have the same problem. I use a DIAdem Professional Edition with win 7. For some time I could ignore the problem by opening DIAdem2010 as administrator.
Now the error occurs also in this case.
Could you help me?
Unfortunately I use a plulgin going DIAdem of 2010 and not on DIAdem 2011, and I have to finish a job
Message 13 of 14
(1,519 Views)
Sorry, I had not seen the other answers. I solved the problem by installing the SP1 from this link.
http://joule.ni.com/nidu/cds/view/p/id/2254/
Thanks anyway
bricco
Message 14 of 14
(1,517 Views)
