DIAdem
DIAdem 2015 fails to launch (Win 7)
Whenever I try to start DIAdem 2015 on my Windows 7 machine, I get the error "Diadem: DIAdem.exe - Entry Point Not Found". Here is a screen image of the error.
I tried re-installing DIAdem mutliple times but get the same error. (I also have DIAdem 2012 on my PC and it worked fine before, now that is also giving the same error).
Also DataFinder.exe is not working and fails with the same error. One of the messages said re-installing NI-USI from the DIAdem DVD will fix this problem. I found NI-USI Version 15 on the DVD and tried to install it, but the installer would not install NI-USI 15 and says it cannot install because a higher version is already installed. I cannot find NI-USI under Control Panel>Programs and Features>, so I am unable to uninstall the corrupted NI-USI which is probably causing all these errors.
Can you please help? Thank you.
(4,477 Views)
Accepted by topic author RagMan
Hello RagMan,
I agree that USI is probably corrupt. It seems that you have a mix of old and current USI binaries on your harddisc, which causes this error.
This is very special and I like to discuss possible solutions with you  - of course I will post the outcome here.
Please post your e-mail here so that I can get into contact with you.
Thanks, Dieter
National Instruments Engineering GmbH & Co. KG
(4,458 Views)
Hi Dieter
Thank you for your response. My email is sraghuraman@oh.hra.com.
Sincerely
Sundaram Raghuraman
(4,435 Views)
Hi Dieter
DIAdem is working now. I did a repair installation of DIAdem that seems to have fixed the corrupted files.
Thanks for looking into this
Sundaram Raghuraman
(4,391 Views)
