DIAdem
DIAdem 2019 displayobj Issues
In DIAdem 2019 (View Panel) when I switch to a curve cursor the y cursor does not automatically appear in the legend anymore.  This has to be added manually for each area.  I am trying to write a script that will do this, but am having issues with displayobj as it says it is no longer supported.  However all the examples in the help file still use displayobj.  Is there a setting to turn this functionality back on in DIAdem 2019 or is there a different way to access the legend options in a script?  The code I was trying to use is below.
dim Area, LegendItems
FOR Each Area In VIEW.ActiveSheet.Areas
    Set LegendItems = Area.Displayobj.LegendItems.Add("CursorY")
     Error in <ViewAddCursorY.VBS> (Line: 12, Column: 5):
     Object required: 'Displayobj'
When I tried to make it smarter by only adding cursor Y to areas that don't already have, it I get the error below for displayobj.
     Error in <ViewAddCursorY.VBS> (Line: 11, Column: 6):
     Object doesn't support this property or method
(2,361 Views)
Accepted by topic author JSal85
Hi JSal85,
The DisplayObj is still available in DIAdem 2019.  I suspect you had a non-CurveChart2D area in your active sheet that your script was tripping over.  Try this:
    IF Area.DisplayObjType = "CurveChart2D" THEN
        Found = FALSE
        FOR Each Item In LegendItems
            IF Item.Name = "CursorY" THEN Found = TRUE : Exit For ' Item
        NEXT ' Item
        IF NOT (Found) THEN Call Area.Displayobj.LegendItems.Add("CursorY")
    END IF ' Chart2D Area
NEXT ' Area
Brad Turpin
Senior Technical Support Engineer
(2,287 Views)
@Brad_Turpin thanks for the reply.  My areas were all CurveChart2D.  However your suggested code worked fine.  Thank you!
(2,266 Views)
