DIAdem
DIAdem 2020 analysis menu option 'Generate Time Channel' - all controls frozen
FYI.. All of the controls except for the X in the upper right corner of the dialog for 'Generate Time Channel' are frozen and they will not accept input. This includes the "OK", "Cancel", "Calculate" and "Help" buttons.
Go to the Analysis panel.  Select the menu option 'Channel Functions' and then 'Generate Time Channel'.
DIAdem 20.0.0f7762 (64 bit).
(1,500 Views)
Hi Mark,
Tried this in SP1 of 2020. It worked in that version.
Paul
(1,456 Views)
Hi Mark,
I believe you that your DIAdem 2020 has that ANALYSIS dialog which is unusable.  However, when I call up that dialog in my DIAdem 2020, it's fully operable.
Do you have any virus checking software active when this happens, maybe?
Weird,
Brad Turpin
Principal Technical Support Engineer
(1,448 Views)
I turned off my virus protection software, and I still experience the issue.
Paul tested it with DIAdem 2020 SP1 and reported no issues, so maybe it will go away when I upgrade.  I can't upgrade at the moment because I am in the middle of a project that requires me to use the original release of DIAdem 2020.
The command works fine when the script function is called.  I just wanted to inform NI of the issue.
(1,442 Views)
