DIAdem
DIAdem 8.1 Soft/Hardware Clock
Hi
I am using DIAdem 8.1 with a 6023E and NI-DAQ 7.2. When reading analog voltage from a channel (unreferenced, single ended) readings are random (just like no sensor is connected to the attached SCB-68), but only when using software clock (100 Hz). When using hardware clock (same rate) everything works fine.
Problem occured after reinstalling Win2K on the system.
(3,251 Views)
Dear Themad,
I have try to reproduce the error without success.
It seems, as if your settings hardware or software are wrong.
Try to create another channel on your 6023E board.
Hope this fix the problem,
best regards.
SebastianN
(3,251 Views)
