DIAdem
DIAdem 8.1(sp1) Ger - Command "ChnTTICalc()" ?
How Do I correct use the Command "ChnTTICalc()" in accordance with FMVSS214 ?
a) Filter the Op-Channels with FIR100 before ?
or
b) Take Pre-Filtered Channels for "ChnTTICalc()"
or
c) a) and b) wrong ?
It isn't for me clearly from the HelpText for the "ChnTTICalc()" .
Thanks for your help !
(3,946 Views)
The following pre calculations are done by the ChnTTICalc()function:
reducing the clock rate to 1600Hz (sub sampling)
remove the bias
filter with FIR100
transfer the reduced clock rate to the original one
I hope this is the information you are looking for.
Kind regards
Walter
(3,946 Views)
