DIAdem
DIAdem Application Error (mfc71u.dll)
Hi Michele,
You can email your scripts etc. to brad.turpin@ni.com
Brad Turpin
DIAdem Product Support Engineer
Message 11 of 12
(1,166 Views)
Hi, thank you for the answers.
The script, that I'd sent you, for a complete proof analize 1410 brake application; for example this night I've run the test and I've got the error at the brake 723 (on the PC with DIAdem Base); I know that isn't better wait 1410*5seconds but I haven't got the error in the initial brakes.
I've run the test on 2 pc :
1) with DIAdem Base:
- I need to use CL() instructions; otherwise I've got the error for "Invalid Field Index";
- Every analized brake the virtual memory increase; it doesn't happened on the PC with DIAdem Pro;
(in this DIAdem there are not extension)
2) with DIAdem Professional:
- I don't need to use CL();
- The virtual memory used is the same for the complete proof;
(in this DIAdem there's Gfs_Ni.dll)
Thank You
Message 12 of 12
(1,148 Views)
