DIAdem
DIAdem - Default Plot Curve Colors
Hello Everybody,
I'm using DIAdem to evaluate my measurement data.
So if i want to plot a curve in a graph, the first curve default line-color is always red, the second green, the third blue and so on... It seems to be the sequence of the color palette in the adjustments.
Is there a opportunity to change the default sequence? e.g. that the first color is blue, the second color is green...
Thanks for the effort,
chrischros
(3,354 Views)
Accepted by topic author chrischros
Hello Chris,
From what I remember it is not possible in the settings. Which seems confirmed by the fact the this Idea Exchange is still running. Yet, that workaround might help you.
Hope it does 🙂
CLAMaxime -- Kudos are a great way to say thank you
(3,336 Views)
Oh nice! The workaround works quite well.
(3,309 Views)
