DIAdem
[DIAdem] How can I trace a data range from a data channel?
I am looking for a way to trace a range of data from a data channel using DIAdem script.
Right now, I can only trace an entire data channel.
Is it possible? I do not want to split a data channel in order to trace a part of it...
Thank you.
Regards
(5,396 Views)
Here is an illustration of what data I want to trace (only selected values) :
(5,392 Views)
Looking at your post I think that the ChnFind function will meet your requirements. You could use ChnFind to give you your indicies of 308 and 320 respectively thus performing your "trace".
Regards
Matthew
(5,386 Views)
Thank you Matthew but this function returns line number. I already have the first and the last line numbers.
The term "trace" is not appropriate, sorry I am French.
I need the function or the code which allows plotting (not copying data or calculating on a new channel) only this range of data (time channel + data channel) in the data VIEW.
Regards.
(5,381 Views)
I'm not sure you can do what you are asking without creating two new channels which contain your data subsets. In a script I would find the start and end rows of the data I was interested in and use the following commands to create two new channels:
ChanCopyExt - to create copies of your channels.
DataBlDel - to delete the contents of the two new channels you have copied.
DataBlCopy - to copy only the rows you are interested in from your original channels to your copied channels
et voila. There may be variations on this but this is how I currently do it in a script myself. I'm looking forward to reading other forum members responses myself now.
Bon Chance.
Matthew
(5,373 Views)
Hello Tenanio,
I believe this will answer your question:
I am assuming in my code that you have a VIEW layout with a sheet called "Sheet 0" which has a 2D-graph in the top area (as can be seen from the screenshot below):
Copy this Code into SCRIPT and run it, it should display the data the way you had described:
View.Sheets(1).Cursor.Type = "Band"
View.CoordinateWnd.Visible = TRUE
View.ActiveSheet.Cursor.X1 = ChD(305,"Date_Mesure")
View.ActiveSheet.Cursor.X2 = ChD(320,"Date_Mesure")
View.Sheets("Sheet 0").Areas("Area : 1").DisplayObj.XScalingMode = "RangeScroll"
call wndshow("View")
 Please let me know if this works for you and if you have any additional question.
       Otmar
Otmar D. Foehner
(5,368 Views)
Hello Otmar.
Thank you for the answer.
It is working but user can change zoom properties and modify the curve aspect. Is there a way to write the data range directly in the 2D axis system properties ?
Excel can do that (by using cell address)
(5,349 Views)
