DIAdem
DIAdem Integration from acceleration to velocity
Hello, I have recorded acceleration with a 3-axis accelerometer and have converted the voltage to m/s^2.  From here I use DIAdem's Crash Analysis to get the resultant and highpass this channel at 0.05Hz to remove DC offset as suggested in previous discussions. Then I integrate this channel to  get  velocity. However, the numbers I achieve are certainly not velocity. Please advise.
(3,734 Views)
Hello, GTD
Could you supply a sniplet of data please?
I tried intefgration over some simulated data and it seems to work straight from the box - but simulated data are always wellbehaved...
Michael
(3,724 Views)
