DIAdem
DIAdem: Legend for speed color in map route
We use DIAdem 2020 64-bit for the report creation of our on-road test. I generate also the map of our test route in our reports and I use the vehicle velocity channel as the Color channel. Is there any possibility to add a legend for the velocity to the map? I couldn't find any way to achieve this.
Thank you
Marek
(555 Views)
Hi Marek,
It sounds like you're doing some great work with your on-road tests! To add a legend for the velocity to your map in DIAdem 2020 64-bit, you can follow these steps:
Open your map in VIEW: Ensure your map is displayed in the VIEW environment.
Access the legend settings: Navigate to the legend settings within the VIEW environment.
Add the velocity channel: Include the velocity channel as part of the legend.
Format the legend: Customize the legend to display the velocity information appropriately.
(518 Views)
Hi Roxanne,
Thank you very much for your swift reply. The thing is I cannot find the legend settings. Could you please point me to the area where I could find it? I attached a screenshot of my user interface in DIAdem View.
Thank you
Marek
(472 Views)
