DIAdem
DIAdem Script: Goto and Continue are not working
Hi All,
  I am having trouble using the 'Goto' and 'Continue For' lines in DIAdem script.  Does anyone know if these are disabled in DIAdem or if I am doing something wrong.  Take these examples below for instance:
Goto:
option explicit
dim a,b
b=""
for a=1 to 50
  if a=10 then goto Printer
  b=b&" "&a
next 'a
Printer:
msgbox(b)
 reports an error directly after the 'goto' text
Continue:
option explicit
dim a,b
b=""
for a=1 to 50
  if a=10 then continue for
  b=b&" "&a
next 'a
Printer:
msgbox(b)
 Reports an error right after the 'continue' text.
Please shed some light on this.  Thanks!
(6,123 Views)
Accepted by topic author GT_Mark
Hello GT_Mark,
In VBS is "GoTo" only associated with "On Error Resume Next". In all other cases "GoTo" and "Continue" are not part of the VBS command set. (Please keep in mind that DIAdem supports VBS and not VBA or VB.) Your example can be changed as follows:
Option Explicit
dim a,b
b=""
a = 0
do while (a < 10)
  a = a + 1
  b=b&" "&a
loop 'a
msgbox(b)
Greetings
Walter
(6,113 Views)
Thanks for the reply.  Unfortunately the workaround you suggest does not work for my particular application.  I'm just going to have to reformat the Sub.  I think using a Select Case will take care of things for me.
Thanks again for clarifying a difference between VBS and VBA.
(6,104 Views)
