DIAdem
DIAdem Start with parameter: more than one parameter possible?
Hi all,
is it possible to start DIAdem with more than one parameter?
I want my users to start DIAdem with a certain desktop.ddd and start a script.
Is there any workaround?
(3,864 Views)
Hello themad!
DIAdem supports multiple /C commands in the command line. In your use case only one /D and a /C command is necessary.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,863 Views)
Thx for you fast help.
Can you give me a quick example, I seem to not get the syntax correct.
(3,861 Views)
No problem, here is an example:
/D"MyDesktop.DDD" /C"T1:='My T1 Value'" /CR1:=1.234 /C"ScriptStart('My Start Script.vbs')"
Be sure to wrap every command with " if there is a space in the value. You have to use DIAdem formula syntax.
Matthias
Matthias Alleweldt
Twigeater?
(3,857 Views)
