DIAdem
DIAdem VIEW - How to display text channel data?
Hi all,
I have several channels of data, one of which is a text channel. The channel usually contains an empty sting or novalue but occasionally contains a short string.
I'm aware I can display the text in a channel table but this doesn't work for me.
How can I display the text on a 2D axis system?
Craig
(4,561 Views)
Accepted by topic author UKCraig
Hi Craig,
You didn't mention your DIAdem version.  In recent DIAdem versions you can click on the [...] button to the right of the curve configuration in the dialog and then choose the "Label" tab to select the string channel.  I verified that this worked all the way back to DIAdem 2014.  Perhaps the feature existed prior to DIAdem 2014, I'm not sure.
Brad Turpin
DIAdem Product Support Engineer
(4,517 Views)
Hi Brad,
Thanks for the pointer, I never would have found it without your help!
Doesn't matter now but I'm using 2015 SP2.
Craig
(4,507 Views)
I'm running DIAdem 15.0.2f6347 Service Pack 2 (32-bit) and wish to display the contents of a Txt channel on a Report sheet.  The datagroup is MetaProperties and the channel is Gen_Description.
(2,365 Views)
I'm running DIAdem 15.0.2f6347 Service Pack 2 (32-bit) and wish to display the contents of a Txt channel, in a text box, on a Report sheet. The datagroup is MetaProperties and the channel is Gen_Description.
(2,351 Views)
