DIAdem
DIAdem basic - scripts
I work in DIAdem Advanced but create scripts that others who work in the BAsic version need to use. I currently set their machines up to run as a start script. However sometimes they want to use DIAdem for other purposes so the script is not appropriate.
1. Is there any way other than using a start script to run a script in basic?
2. If that is the only way, is there a way to have the script ask them if they want to use it and give them a way out?
It is annoying the other users to have this always want to run when they only use it about half the time.
Thanks!
(4,456 Views)
Accepted by topic author KarenD
You can create a Desktop shortcut with a start script as parameter like this:
"C:\Program Files (x86)\National Instruments\DIAdem 2015\DIAdem.exe" "/CScriptStart('C:\Data\StartScript.vbs')"
Then you can have one shortcut with and one without start script.
Another alternative is to use the script group in any module to start any script:
If you want to ask the user whether to run a start script or not you can use this as a start script in DIAdem settings:
if MsgBox("Do you want to run the start script?", vbYesNo) = VBYes then
	call ScriptStart("C:\Data\StartScript.vbs")
end if
Only if the user clicks yes in the message popup another script (main start script) will run.
Regards
Christian
CLA, CTA, CLED
(4,342 Views)
Christian,
Thank you so much! The last solution is the best for my use. I really appreciate the help!!!!
Karen
(4,319 Views)
