DIAdem
DIAdem data stores
Is it possible through labVIEW program to create TDM file of data which i get through DIAdem data stores?
(4,126 Views)
It is actually very easy to write TDM files of data using LabVIEW and then importing this data into DIAdem. There's actually an express VI called Write to Measurement File that can write data in the TDM format. You can get to this VI by right clicking on the block diagram and going to Programming>>File I/0>>Write Meas File. After writing this data to a file you can just find this data using the DIAdem Data Finder and analyze it or include it in a report.
Hope this helps!
Lars
(4,106 Views)
hi,
Through scripting is it possible to load data to data portal(through citadel data base)?
(3,988 Views)
Yes, I'm attaching a sample VBScript that programmatically loads a particular time window from a Citadel (DSC) data base.  Note that you can also load data traces interactively from a Citadel (DSC) data base.
Brad Turpin
DIAdem Product Support Engineer
(3,965 Views)
