DIAdem
DIAdem doesn't correctly parse Windows path names
It seems that DIAdem won't correctly parse path names that have dots in them, e.g. DIAdem interprets c:\mydir.mydomain\myfile.dat as c:\mydir\myfile.dat. Am I doing something wrong? Is there a workaround?
(3,742 Views)
To reproduce this problem I've done the following test:
Save values in the file "test.test.test test.DAT", load this file, changed something, save and load again. This works fine and without any problems.
I'm working with DIAdem 8.10 and XP as OS.
If you can reproduce the problem with DIAdem 8.10, please send me an example file so that I can do some additional tests.(Therefore you can use the following email address walter.rick@ni.com)
I hope this will help you.
Regards
Walter
(3,742 Views)
