DIAdem
DIAdem freezes in VIEW when displaying y-cursor in the legend AND there are enough channels to require a scroll bar in the VIEW area
Hey guys,
I stumbled across an issue that is very repeatable for me where DIAdem will freeze and sometimes throw an error code when in the VIEW tab. I have been able to isolate the following scenario which will always generate the issue for me:
- DIAdem versions 2023 Q4 and 2024 Q4 (issue does not exist with 2022 Q2....those are the only 3 versions I tested)
- Load Data
- VIEW tab active
- Data is plotted in a VIEW area AND the number of channels in the VIEW area requires the Legend to have a vertical scroll bar
- "CursorY" is selected to be displayed in the Legend properties
- If you then double-click into the 2D Axis System of said VIEW Area and just hit OK, DIAdem will freeze and sometimes throw an error code (screenshot below)
  -  Sometimes it freezes on the 1st try, but sometimes it requires 2 or 3 attempts to get it to freeze
If I decrease the number of channels or if I increase the size of the VIEW area in order to get rid of the vertical scroll bar, then I cannot get DIAdem to freeze by opening/closing the 2D Axis System Dialog Window (i.e. it works properly).
I have attached an example data set and a few different VIEW layouts which turn this issue on/off.
Please let me know if you need more information.
(693 Views)
