DIAdem
DIAdem memory increase
Hi, I have a question about the memory used by DIAdem.
On one PC with DIAdem Base, I this code:
For I = 1 to 10
    Call DataDelAll
    Call DataSetLoad("EXAMPLE.TDM")
    Pause(10)
Every time DIAdem load the file, I see in the tasks manager, that the memory increase, even if before I use DataDelAll.
If I run the same code on other PC with DIAdem Pro the memory is every time the same.
Do you know if I need to configure something in DIAdem Base to avoid that memory increase???
This is a problem for me because sometime the process use all the RAM available and some of my problems that I describe in other my posts are probably due by low memory.
Thanx a lot
(4,029 Views)
Hi Michelle,
We will need to try to reproduce this error in order to advise you.  Can you tell us what version of DIAdem you are running?  It really sounds to me more like an issue with the particular computer that DIAdem Base happens to be installed on, rather than a difference between DIAdem Base and DIAdem Professional, but we can at least try to reproduce it.  Theoretically there should be absolutely no difference between the two versions, since the same functionality installs in both cases and the only difference is what interactive features are activated in the licence file.  When running a VBScript, I do not believe there is any difference between DIAdem Base and Pro, at least not since DIAdem 9.1.
Brad Turpin
DIAdem Product Support Engineer,
(3,999 Views)
Hi Brad,
the PC is an HP Pavilion T3340.IT Athlon 64 3800+ 3 2400 MHz, 1024 MB RAM
with DIAdem Base 10.0 with service pack SP1.
Thanx a lot
(3,991 Views)
Hi
I installed diadem 10 base but i didn't see this behavior.
are you able to reproduce it in another PC?
Beppe
(3,974 Views)
