DIAdem
DIAdem wav files
Hi guys, sorry if this is the wrong place to post but hoping someone can help me out. How can I save channels as audio files? I can save wav files but they are silent, online info seems to suggest I need to scale it but I’m not sure what is required. Thanks, sorry if this isn’t appropriate here
(1,122 Views)
Not sure what the problem is without looking at an example file you are working with or any other hints.  What I did is took the example TDMS file (attached) and saved it as a WAV file using this command:
Call DataFileSave(MyFolderPath & "file_example_WAV_1MG_DIAdem.WAV", "Audio", True)
The resulting file plays fine.  The TDMS stores two-channel LPCM audio sampled at 44.1 kHz (or 8000 samples per second or 0.000125 seconds step width) with 16 bits per sample.  You can use this as a reference for you scaling issue or maybe provide some more info on your issue/requirements.
(1,101 Views)
