DIAdem
DIadem 2019 crashes when opening wizard for "%" ASCII files
i think i discovered an unwanted behaviour of Diadem 2019. When opening the Data plug-in wizard for ASCII files that have in the name the "%" character the software crash sistematically. If i remove the "%" from the file name the wizards run smoothly.
Let me know if the problem is reproducible to others.
Francesco
(3,366 Views)
Hello Francesco
I cannot reproduce the crash with a copy of Example ASCII file
DataPlugin_Proc%Kopie.asc
Which ASCII file causes the crash?
Regards, Sandra
(3,299 Views)
Hi Sandra,
that's really strange. I'm going to attach you the file to this message. Just to be easier to reproduce, i summarize the steps:
1) Add the file "1Ciclo_20%strain_nopause.txt" in a folder that is indexed by DIAdem;
2) Look for the file in the DIAdem Navigator, right-click, "Open with...";
3) In the new window opened i choose "Wizard..."
...and then DIAdem crashes
I get the same behaviour if, in the Navigator panel, i click on the "Wizard for loading a Text-Based Data File" button and then select the "1Ciclo_20%strain_nopause.txt" in the pup-up.
Please notice that if i remove the % character from the filename everything goes smoothly, so it should not be a problem with the file content. Moreover, if i already have a DataPlugin able to read that file, i can even read files with the % character. So it should be an issue related to the Wizard loading a %named text file.
Francesco
(3,293 Views)
Hi Francesco
Thanks for the file and the steps to reproduce.
The crash is reproduceable.
Regards, Sandra
(3,286 Views)
Note: I've removed the "s" after the % in filename and the file can be loaded.
(3,252 Views)
Hi Sandra,
it's legit to suppose that "%s" is bad interpreted by the Data Plugin Wizard, considering that in many languages (i.e. SQL) is a code tag. I don't need workarounds. I removed the "%" because the same consideration you did removing "s" char. I just thought that this is an unwanted behaviour and i opened a post to communicate it.
Francesco
(3,245 Views)
The issue is fixed in DIAdem 2019 SP1.
Best regards, Sandra
(3,166 Views)
