DIAdem
Data Load into Diadem via Script
This bellow is my Script to Load Data to Diadem...
My question: Is there a possibility to access from a sript directly the dialog
of "DIADEM DATA"-"Daten Laden"?
It would be much more bether because in this case i don't need
this script below for checking the amount of various data-types.
Call FileNameGet("Any","FileRead",DatFilePath_ & DatFileName_, _
"Diadem-File(*.dat),*.dat,MME-File(*.MME),*.MME,All Files (*.*),*.*",,"","YES")
If (DlgState ="IDOk") Then
DatFileName_ = FileDlgFile & FileDlgExt
DatFilePath_ = FileDlgDir
DatFileType_ = Upc(Right(FileDlgExt,3)) 'save data-type
Select Case DatFileType_
Case "MME"
Call GpiFileLoad("MMEDriver",FileDlgName) 'load .MME file
Case "DAT"
Call DataLoad(FileDlgFile) 'load .Dat file
Case "ISO"
call ......... 'load .ISO File
Case Else
Call MsgBox("File " & DatFileName_ & " loading not possible!")
Exit Sub
End Select
End If
(6,438 Views)
Currently I don't know of a way OTHER than the one you are currently implementing to do what you want. This is the way I've done it for years and continue to do.
(6,438 Views)
Hi Peter28,
DIAdem calls the same Windows SDK funtion that FileNameGet() does, so you are already effectively calling the dialog that you get when you choose File>>Open. The only difference is that the possible file types are included in the extension filter parameter, as per:
FileDlgFilt = ""
FileDlgFilt = FileDlgFilt & "DIAdem data file (*.dat), *.dat,"
FileDlgFilt = FileDlgFilt & "LabVIEW LVM file (*.lvm), *.lvm,"
FileDlgFilt = FileDlgFilt & "Excel file (*.xls), *.xls,"
FileDlgFilt = FileDlgFilt & "ASCII Import (*.*)"
FileDlgCaption = "Select the data file to load"
Call FileNameGet("ANY", "FileRead", FileDlgDir, FileDlgFilt, "", 1, FileDlgCaption)
Brad Turpin
NI
(6,438 Views)
Thanks for answer !
(6,438 Views)
Thanks for answer !
(6,438 Views)
